Guide on data2ext!
Re: Help please data2ext.;)
im actually having trouble unmounting mmcblk0p2
Im using terminal emulator app and type su to get root access. Once I do that I type:
mount|egrep mmcblk0p2
and I get a message:
/dev/block/mmcbl0p2 on /sd-ext type ext3 (rw,noatime,nodiratime,errors=continue,barrier=1,data=writeback)
How do I get it to unmount?
edit: I tried "umount /sd-ext" without the quotation marks and it didnt work for me
Did you partition it? What rom/kernel? What steps have you completed already?
Ok guys I'm goin to do a step by step how I did mines remember it has to be a fresh installed rom so nothing is mounted ok I will be back in 30
"Quote" its goin to be on first post....
Sent from my LG-LS670 using Tapatalk
Not completely sure what this means, but are you coming back to cm7? ;)
yes, i partitioned it using xionia clockwork recovery. Im on ath3nos CM7 & using xionia 014 kernel.
The steps that I did was fist partitioned the SD to 1GB with no swap.
Then I got stuck on the post above, I didnt know how to unmount because I got a message "unmount: not found"
Boy I been on cm7 since the 9th that it came out I have not incounter any problems :) but I'm just trying to help other.....
unmount isn't a command. Try umount.
Reactions: ens04
wow, I'm so embarrased.
ill give it a try once more
manny29, you should include in your instructions that anyone may use the ext4 option as well.
Also, "somewhere" is linked in my first post of the thread if you just want to point people there for the download. Good job.
I got it to work & I now have 1GB of internal space. Thank you everyone for all your help.
Thanks will do but I haven't actually Upgraded to ext4 but goin to read it so It can come to my understanding .....
Re: Guide on data2ext!!!!!!!!!
One is not really better than the other. Its just an option. Its the one I use. Supposedly its faster. Either way I wanted everyone to know that its an option. ;)
I found this modified data2ext on the optimus v forums and it does work with Reborn 2.2.4 just create a partition in recovery, adb shell in recovery, follow instructions @ Data2ext CyanogenMOD - UPDATE 26/01/11 - xda-developers, i did the new user ext4 instructions, then flashed this modifed zip...boom 512MEG of internal storage when I booted up, no more messing up marketplace...
Nice.......
Besides. Of this I did a full wipe and then install the ath3nos cm7 rom and gapps I restarted system let it turn on then went back to recovery and went an did the partition install the data2ext2-v7.zip and reboot system. And went to terminal and type code "data2ext --enable" and it work no problem ...
ok how do I do this on the drew mod? I tried flashing the data2ext zips with xionia cwma v1.2518.6 but it is a no-go so far.
You have to disable the signing before you apply data2ext.zip
You also have to format a partition of your sdcard to ext4 first....
ok I am doing the format (yes I did a backup) but my question is how long does this take it is an 8gb class 4 it has been on the please wait screen for a while now
Aruz530
