[GUIDE] Optimus V ZVJ
Updated my Guide to include your guide!! :D
I like how we both always end up merging our work! xD
@sammyz, how do you do the information windows in your guide??
i wanna include a few in mine to make it look nicer :p
Reactions: sammyz
I had working data/calls on zvj, but I never got mms working. I was to tired. Then I went back to zv5 for testing purposes. Havn't gone back yet.
Well I'm done with this. Gave my little sister the OV after having everything zeroed out but I'm not going anywhere.;)
We just need someone to build or port a rom with the mms fix asadullah posted... It's a little out of my league... Good thing I don't really use mms much
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
Where is this fix he posted? I forgot.
Sent from my shole using Tapatalk 2
[ INFO] words here [/INFO ]
no spaces when typing the brackets and INFO....just like making things bold.
But on tapatalk you will see the tags and not the info box.
And ROFL soooo true.
Sent from my Optimus V running Optimus S firmware on MetroPCS
I've been trying... I have my build prop and apns edited to work but I'm having trouble with adding the cdmasmsdispacher added to classes.dex
Yeah... It's running great and I don't see the need to go back till I get bored again lol
Edit: also i was playing with the S firmware before sammyz guide but never could stay because of no data
I would have to downgrade but there's an update.zip to do it.
really? well that's easy. but then you'd have to root, install custom recovery again and flash the rom. right?
Yep root and recovery again same rules apply as the zv9 update
Edit flash stock recovery boot to it factory reset and install update.zip shouldn't break data either
websitedesig117
