[GUIDE] Optimus V ZVJ
You know... we should have a zvd to j patch for ppl that do this guide... with that there's no reason to go back to vm670 firmware as all the roms still work.
It is and I helped with it but when he made it flashable he added the OS keypad and other files. Not needed to make all VM rooms work on zvj radio
One with the VM670 keypad will be here later today.
The only reason I still include everything in the patch, is kind of there as an Easter egg, I'll later remove some of the things not needed, and include a scripted Easter egg.
sent from my un-dead sammich.
Reactions: thewraith420
I just added link to the patch in the OP :)
@thewraith420, I flashed my OV 3 times while in e-mode with the kdz flasher with my homemade ZV5 cab converted to kdz. Now it boots but no recovery mode at all O.o
Reactions: nitestalkr
Try the good ole recovery install with terminal emulator
...try again with lgnpst or kp500 to get recovery back?
Hmm did you read from lgnpst before going to dfs to make the edit
Yep, I think that's what I was doing wrong. Got data working now!! WOOHOO! am I the only other person yet to do this besides Wraith? Now to root it, install custom recovery and restore back to my quattrimus and maybe try out hydro or something :)
I think its me you and Sammy who have done it.... I'd guess asadullah too but he Hasn't posted about it.
Tapatalk'n it from my VM670 running LS670ZVJ Baseband
Well, do you have root? It sounds like you need to re-root and install a recovery.
Defeats the purpose
also defeats the purpose.
I went to ZVJ not rooted.....haven't gone to ZVJ rooted....so busy.
I still never flashed a single jellybean ROM -_-
Defeats the purpose
I haven't either dispite being able to.. I been enjoying hydro rom and jb is just too new right now
I'm having insane difficulties just trying to root the freaking thing on zvj. I keep getting a write: no space left on device message and then I check and still no root.
Did you run optiauto
And at what step did you get that error
Sent from my VM670 using Tapatalk 2
Come to think of it if your unrooted and on zvj your already to far and have to revert then run run gingerbreak and from the computer use optiauto to update and root zvj
DonJrPlayz1234
