[GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stock
Status
Not open for further replies.
Re: [GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stoc
have you tried pulling the usb cord out from both sides? maybe try rebooting your computer. it should work. And if it doesn't, there's another method to fix it, but much more complicated.
yes i have. out of curiosity whats the other method?
The other method that unbricks the phone will zero out your MEID and you will lose your AAA/HA keys. That means you will never have data again.
Sent from my Optimus M
Try this, on the first time a restart option appears, unplug USB, replug USB.
On the second time you get a restart option, unplug USB, pull battery, plug in USB, press restart, put battery in. If this still fails, you may have a bad USB cable.
The other method involves getting onto zvd Optimus S firmware using lgnpst. The guide is here. It says its for advanced users because it is. But you have no other alternative. It's very involved, especially when trying to get your data working again, so do not just go around trying different things out. You have to be very precise in backing up your data information, HA and AAA keys, etc. You will probably need help; that's what this forum is for. I KNOW this will work if you soft-bricked your phone and you do it correctly. This is a different program than kp500, and doesn't seem to have the problems that kp500 does. If it doesn't work, it probably means you hard-bricked your phone and Optimus is dead.
Now, I know you said you aren't able to boot into anything. However, you may be able to boot enough for you to get a com-port open. Just plug your phone into your computer and hold the power button just like you would if you were turning it on. after a few seconds let go. You should now be either at a black screen or an lg splash. on your computer click start, open device manager, and look for Coms/ports. The android serial one should be in there. if it isn't pull battery and put back in. Try to boot into recovery. Should be a black screen. look at your device manager again. NOTE: This will only work if you can get a com port open. If you cant, it may work, but you will probably end up with 0 service. :/
THIS IS GOING TO BE A VERY LONG AND COMPLICATED PROCESS, SO I HOPE YOU KNOW A LITTLE ABOUT COMPUTERS AND ANDROID.
I wouldn't even do it, he has no way to backup his AAA/HA keys!!!! You can't get them while in e-mode
If he can get a com port while in any other mode, he's lucky. But even if he turns it on with a power button, it will boot into e-mode.
That's why I said to do the com port thing. If he can get a com port, then he can back up everything! Even if he can't boot up or boot into recovery.
Ahh, really. hmm. well he should try the recovery way of doing it. Other wise, the only OTHER option is to uninstall all of kp500, and use Phatninja55's method. the unbrick.rar dl link is broken, but I can upload it for anyone that needs it. His method involves losing data, but it's recoverable via dfs.
I don't see why using Sprint firmware will work over our own firmware :what:
that second option was just another thing to try. the first option I gave uses lgnpst and it doesn't fail like kp500 sometimes does.
LGNPST is to be used ONLY if all else fails because without an nvs file, you will never get data back. Only used after it fails on multiple computers and I try doing it myself with teamviwer.
That's why I stressed the importance of getting a com port. so he can get his nvs! but I digress. a different computer may solve his problem or you on Teamviewer. what is teamviewer, anyway??
You can get a com port while in e-mode, but it blocks the MEID and other stuff from being readable, the entire NV items are blocked while in e-mode.
Teamviewer is software that allows you to control another's computer, Google it, it's really useful! And it's free :D
Thank you all for being helpful I hope it works when I get home.
Sent from my SGH-T839 using Android Central Forums
I don't know about that error. You should try it on another computer.
Misa ,no recovery either?
Ok, who wants me to unbrick there phones for them?
Won't take me long, I'm an expert.....I created this guide and I've gotten around every error except hard bricks...which I'm sure you're both soft bricked.
Otherwise @ jlerma90
your error is only solved by rebooting, or it's a bad download (which I doubt) or you are doing something else wrong.
Status
tsmtoolpro
