[GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stock
Status
Not open for further replies.
Re: [GUIDE] Unbrick ANY Soft Bricked Optimus V/Return to ZV5 Stoc
I've got working fastboot
Why would we want bootloader? How would that benefit?
Disable anti-virus uninstall then reinstall. I had this problem too Norton thought it was a virus
Tapatalk'n it from my VM670 running LS670ZVJ Hydro Rom
Reactions: sammyz
Disabled virus protection. Uninstalled and reinstalled. Still not there can someone please just send me the exe?
I don't think that will fix it...
If you're running windows XP then idk. I can help you via remote desktop connection by teamviewer. BUT try this:
Enable the Administrator account (This is for windows 7/vista users)
-Click Start
-type "cmd" (without quotes)
-right click cmd
-Run as Admin
type "net users Administrator /active:yes" (without quotes)
type "net users Administrator * " (without quotes)
Hit enter 3 times
Log off
Select the Administrator account.
From now on you will only use this account for the entire process.
Because this program has issues when it is not used/installed via the actual Admin account sometimes. Normally install issues and running issues.
Just found a better way to unbrick/upgrade by using Software update [KDZ] program :D
This will replace LGNPST AND KP500! :) Only have to install one program that lets the non-installed program run without errors (you still need drivers though). This works fine with any operating system and doesn't need Admin permissions to run either!!
I'll be interested to see this. tho I've just been using lgnpst for my needs.
If you reenabled virus protection after it was installed the antivirus probably removed it again you'll have to leave it off till your done with the program.
It finished flashing it, I came from ZVD and flashed ZV5......it wont boot (stops booting at VM logo without sound) and stock recovery won't load...hmmm
I think I need to add a SCR file to the cab.
Sent from my Optimus M
As long as you don't loose e-mode...that would be a real brick that no1 could fix
you can be hard bricked and still have e-mode, ask asadullah....I'm trying again with ZVD firmware this time.
Well as long as we have e-mode there is a way to unbrick right? Or are you saying in some bad bricks e-mode will be there but won't work?
That's what a hard brick is...
Really you only can hard brick if you start trying to mess with the bin file and then try to flash it.
I couldn't get zv5 on after zvd either. I can't remember how I got back now haha. Oh yeahhhh! I used the old unbrick using the optimus s firmware forum to get back to zv5! there's a way to do that. but now that thread's gone.... :/ hopefully it isn't gone off AF.
Status
acxite
