Hardware Versions: 0002 or 0003? Also, HTC called me back about the screen issue..
Hardware Version? (I'm going to add 0001 and 0004 just in case)
  • Total voters
0002 here and I am having screen separation and light leakage only. Everything else is fine.
HW Version 0003 - Very Very Slight Lifting near bottom keys Home and Search. Nothing major or anything in my ideals to bissh about. I have insurance so if it's anything too much, i will just have them replace it. No worries here. I actually have 2 of the phones, one for the wife and one for me, and we both are on 0003 and have a very very minimal seperation and light showing.
0002 - Slight light leakage under the Home button, and the bottom left corner of the screen is slightly raised above the case edge, with a little give if pushed in... Q..Q....
Edit: I think my FM tuner is broken, I tried 3 different sets of headphones and got 0 stations available...and I live in LA, lol.
0002. Light leakage, slight screen lift. Other than that, everything seems fine besides the shoddy FM and WiFi reception. Even get great 4G from inside the home.
Re:
0003 with no issues whatsoever.
- Sent from my HTC Evo-4G using Taptalk Pro.
there is no correlation whatsoever....both version 2 and 3 are messed up....and both are also normal
I have a normal version 2 with just a bad WiFi
0002, leakage on bottom and sides of screen. i think my screen is lifting on the bottom right corner. i have had a zagg screen protector and bodyglove case on it since day one so its hard to tell.
Re:
You don't see the irony in that post... So I guess bad wifi is normal to you? LoL
I have version 0002. Light leak under all but home is worst. Screen lifting a little. Also issues with grounding. So exciting.
How do I find issues with grounding? And I BARELY see light leakage. I'd actually have to go out of my way to look for it.
The one I got on launch day from RS was 0002, had light leakage and lifting glass.
I got two in today, 1 0002 and 1 0003, no light leakage or lifting glass on either, wi-fi is weak on both, not going to test the grounding issue.
Got an 0002 on launch day. It has light leakage underneath the buttons and the glass is lifted at the bottom of the phone as well. WiFi is pretty weak but it is good enough for me. And the grounding issue is also present.
I have 0002 and have bad haptic feedback vibration, and a possible bad proximity sensor, as when I am on a call it wants to black out the screen even if on the table.. No light leakage though.
janbibijan
