Has anyone gotten the OTA kitkat update?
Finally downloading KITKAT on my Nexus 10!!! Got it by doing Google Services Framework trick about three times! I'll let you guys know my experience!
Sent from my Nexus 10 using AC Forums mobile app
Just received the update. Now time to start exploring.
Just received the update to 4.4 today. Really new to Android, but I think I will be making with Smartphone switch as well to the GS4.
What's the framework trick?? Has anyone in Canada received the ota update?
Settings >Apps >All. Scroll down to Google Services Framework. Click it and clear data. Then go to Settings >About Device >Software Updates. I just did it and got the OTA update. St. Louis.
Framework Trick
Settings-Apps-All-Google Services Framework - Clear Data-Force Stop-Check Update
Do it several time if the first try don't work.
Sent from my SGH-T989 using AC Forums mobile app
I just did Framework trick and now my ota worked I have 4.4 now . So far when you click buttons it make a different sound and wifi signal is orange in the settings
Sent from my Nexus 7 using Tapatalk
4.3 to 4.4. took me by surprise, was busy with other things.
I am finally up to date with the NSA patch!
update available here in ga...my battery is too low but it shows that I have the system update available....finally prompted after clearing data for system framework..did this about twice
I stand corrected. Getting some kitkat goodness as I type. 6th framework trick worked like a charm.
Dronevex
