Heads Up ICS 4.0.3 for your phone is ready
So i lost the status bar and cant figure out how to fix it...ive tried reflashing doing a complete wipe before....any suggestions i love this rom but i need my status bar
Yes they are customizable. What apps/folders you put there will show up on the lockscreen.
Thanks. I'll def. Give it a go
BobClockD3
That's a tough one. I couldn't get mine to work through changing via the apn settings. I just gave up & downloaded Go SMS Pro & MMS worked out of the box with that app.
A little lag in bringing up menus & some apps are not optimized for ics & scroll not so smooth. Using the stock sense home launcher lessens the lag. The rom itself is rock solid stable. All except mms work, so the choice is yours if you can deal with a little bit of slow menus it will & has been my daily driver since it was leaked.
so my phone's ear speaker was damaged some how and am getting a replacement tommorrow, so i thought what the h#ll, i'll give it a try. the rom itself is good, however i couldn't get wifi tether to work, which is a bummer cause that is my wifi. any ideas? might just have to wait for an independent rom (or sprint leak). and also a question if i may......... why do think that this phone gets no love. there's plenty of custom roms and what not for the evo 4g and 3d.......why not this one? this phone is BADA$$
Official ICS oughtta be on the horizon any day now.
*Sent from work early bcuz some1 4got teh NSFW tag*
How did you get the status bar to work. That's the only issue I have with this ROM. That and my LED green light keeps flashing and I don't know what it's coming from. Would greatly appreciate it, if you or anyone else could help me out! :)
I just bought the EVO Design 4G for boost mobile and it has ICS 4.03. Already have it rooted. I don't know the first thing about porting but if someone wants it to start building a custom rom and can walk me thought getting it from my phone to a dev, let me know. Or....if someone has already ported the offical 4.03 for this phone, disregard.
i just rooted my design but now i cant get any service let alone bars on my sprint network. any ideas/suggestions
thank you in advance
You didn't by chance remove the battery cover and not put it back on did you ? I know I was having major signal issues but then I noticed the two gold prongs on the battery covers inner side and when i put it back in place i had service again
ok thanks bro ill give that a try i never noticed that the back piece of the battery could be the issue
ill give it a try and let u know if it work or not
thank you again-
RangelS25
