Heaphone Jack no longer works
My 2 cents for this thread !!
My Vivid has the same problem; I was very worry about, so I checked inside and see nothing, all shinny and clean.
I grab some 96 grade alcohol and a toothpick, I cleaned inside and try to wiggle all around; after that done wet the tip of my well cleaned earphones, connect and disconnect; blow well and VOILA !!
all is working fine again ! Thanks you guys rock !!
GOD BLESS YOU. WETTING TIP WORKED. Headphone not recognised solved. Earphones not recognised solved. I licked the 3.5 mm pin / tip of my earphones or say i ran my toungue over the pin and inserted and removed the pin 3 times suddenly and it worked.
If anybody has the same issue that is Headphone not recognised or Earphones not recognized then do try these 2 things:
1. Check if there is any lint in that 3.5 mm hole. Earlier my pin in went like 75% and the other 25% of pin was not getting in. I checked the hole under torch, there was a lint ball.
2. Try above wetting tip method.
Thanks
This happened to me on my DX. Turns out, lint from my pocket got down in there. Dumb sounding, I know. Bend a staple so it's pretty straight, hold the phone upside down and dig around in there a little. Then mail me a $0.25 tip if that was it :)
my phone is the CoolPad Catalyst, and whenever i wiggle the headphones, it works but if i just move my head or the phone it's going to speaker mode, and when this first happened, i was listening to dubstep at school, i freaked out because i thought my battery got fried. and that was in august, so i hope your fix works.
noroldie
