Help - any hack to increase scrolling speed?
My personal favorite is OM-Mandylion
http://forums.androidcentral.com/showthread.php?t=157006
He supports the OS and OV
Really though it'll come to personal choice, make a backup with your recovery and try a few out.
Tapatalk'n it from my VM670 running OM-Mandylion on LS670ZVJ firmware
Thanks. I am going to try that. I was using Hydro, but I like the fact that this one is supported, so here I come!
Sent from my LS670 using Android Central Forums
And if you want a pretty stable cm9 use thekravens cai rom
Sent from my VM670 using Xparent Cyan Tapatalk 2
Just note that Mandylion requires sd-ext so you'll have to partition your sd-card. Also it's good to have sd-ext if you want to try some of the newer ics and jb roms out
I tried a few of the ICS ROMs on this device, found that they take up significantly more internal memory and it just seems like a dev crux to get it to fit and play nice. I found the best performance, feature set, and customizability on this device came using CM7-based ROMs.
NovaShadow77
