HELP! Droid X Stuck after SBF from Gingerbread
randomcrispy
6
Today I Rooted my phone and installed the (rooted) Gingerbread on the phone.
Unfortunately, I forgot to make a backup of the stock firmware, so i SBFed the phone using the directions and sbf file on this
page
The firmware successfully installed but now my phone is stuck on an all black except for the status bar is showing. I can also pull the notification bar down. I have Tried to pull the battery out a couple of times with no luck
Any help I would appriciate!!! Thank you!!! :-\
What happens when you pull the battery? You probably need to pull the battery, put the battery back in, hold down on the home key and power button. You should get a triangle on your screen. Hit the search button (bottom right) then use your volume key to go down to reset. Hit your camera button and select reboot once finished. If that doesn't work than you may need to sbf again.
Reactions: randomcrispy
958ryan
