- Jun 2, 2010
- 15
- 0
- 0
I'm hoping someone can help me with this issue.
When I hold down the HOME button to bring up the recently used apps, HTC Sense UI will always be listed. From that point on, when I tap the HOME button, I get a dialog box asking me if I want to use HTC Sense or Launcher. There is also a check-box to set as default.
When I check the set as default box and select HTC Sense, the Sense UI launches. From that point on, Sense UI will launch whenever I tap the HOME button, but if I hold the HOME button, Sense UI, again appears as one of the six recently used apps and it is no longer the default launcher.
Has anyone else run into this issue? Does anyone have a solution to force Sense UI to stay default?
So far I've tried
- Going into the app manager and clearing Sense UI data and default
- I thought the auto start task ender might be shutting it down so I uninstalled it.
- I've rebooted the device
- I've turned it off and remove the battery
- I've planted a flower in tribute to the Android Gods
All to no avail. Any help will be greatly appreciated.
Thanks in advance.
So far I've tried
Thanks in advance.
