That's weird, I've been running Liberty for 2+ days now and I've never even seen that Liberty start-up animation you are describing lol. I've flashed a ton of changes to the rom as well, themes, fonts, pulldown banner, etc. and I usually had that fugly ANDROID animation.
So I installed my first ROM, the LibertyX ROM. I got finished with the flash, and it rebooted. It comes up, and says Liberty, followed by start-up animation, with th eagle turning, but it won't go past that. Suggestions???
Thanks,
Cool thing about liberty tool box. Just back up all apps and data, wipe data and cache, restore apps, and restore LLP settings from backup. Might be a easy fix.
I'll give that a go, thx.![]()
Just wiped Data and Cache, wiped System, reinstalled Liberty rom and I can tell already that the install is correct this time from a clean install. Got the Liberty startup animation, my Spare Parts doesn't FC from the Liberty settings menu now.
Restoring everything now...
Thanks.![]()
