Hisense Sero 7 Pro - Unboxing pictures (no video)
Yes, I just bought a new Samsung and it's a micro USB.
Sent from my Nexus 7 using AC Forums mobile app
I'm feeling sadly neglected having not received the update yet. Maybe it's being pushed by a single homebrew PC running Windows XP and a dialup line somewhere in a backroom in Shandong province:p
[EDIT: Go figure. Update just came in. Really haven't notice much difference. Hope it allows Maps to play nice. Would have been nice to see a changelog attached]
Still having touch screen issues even when connected to the charger/cable that came with it. Could I have a lemon?
I cleared the Google Services Framework twice and than I hit the update button and I got the update.
Not sure what you did. I stopped Google services running as 2 separate items and rebooted. Nothing happens. What do you mean by 'update' button?
have not rec'd the update either. Currently on P765.6.01.01.00
I've shut down and rebooted a lot the past week. Guess Hisense is taking their time pushing this update.
I did not stop the Google Services Framework, I cleared the data and then went into settings and checked for the update. I had to clear the framework twice before I got the update.
have not rec'd the update either. Currently on P75.6.01.01.00
Did you try clearing the Google Services Framework and than checking for the update? In most cases it works.
How do you access Google Services Framework? Do you need to be rooted? I searched for it using ES File Explorer and couldn't find it.
I just got the update and now I can't get app updates in Google Play. It's says error connecting to server. I had four apps that have updates available today and none would update.
Sent from my M470BSA using AC Forums mobile app
Go to settings-> apps-> scroll over to all-> find Google Services Framework-> click clear data. Then go to settings and check for the update.
marik999
