"HOME" on GALAXY S7 edge
sexy4043
18
How do I remove or change the "home" on the GALAXY S7 EDGE always on screen?
I don't think that you can remove home, but you can remove San Jose which is in the same time zone
Re: "HOME" on GALAXY S7 edge
Try going into AOD settings (under display settings), go into clock style, scroll to the dual time zone clock style and there should be a tiny gear icon on the bottom right. You can add/remove cities in here.
The problem is that HOME is not MY home and the time is wrong in relation to Mexico.
liquidsnake757
