Home screen mode constant reset
U
Unregistered
From time to time whenever I try to go to home my phone will pop up with a message telling me to choose between standard or easy mode how can I fix this
anon8380037
5,171
Re: home screen mode constant reset
Hello. Welcome to Android Central.
A regular query with Samsung phones.
For the easy way you can go to General - Default Applications and set Home default there (if you have that setting).
The way I and many use is to go to Applications Manager (above Default Applications) - scroll across to All - down to Touchwiz Easy Home and Touchwiz Home.
Touch for App Info and check that Touchwiz Home is set as default. You cwn also check that Easy Home is not, and clear any cache and data, though it will still be active.
Sent from my SM-N9005 using Tapatalk Pro
Sáenz
