How can I get back out of the adb sideload screen?
i have q mobile i5. How can I get back out of the adb sideload screen?
Please i tried power + volume up buts its not working on my htc one. plz help me
Solution here,
Open the cover of SD Card you'll find a small hall behind SD Card place put a needle and press for 5 Seconds the phone will switched off
Restart it and join.
Done
Ahmed Samy Hendy
I try holding buttons up our down and it doesn't work,I cannot remove battery, it's sealed
I got out of message, but it went back to FTM
Got it, ty
The keys you need to press restart your device in fastboot mode, from where you can re-select the appropriate option.
These keys are device-specific!
You can find them out on the official Android website:
Match your device with its "Codename"
https://source.android.com/source/running.html#selecting-device-build
Find the key combination for the "Codename"
https://source.android.com/source/running.html#booting-into-fastboot-mode
Alternatively, just wait for a bit. While writing this post adb sideload timed out and brought me back to the menu ;)
its not working
Thanks a lot but
we have to press the volume down + power for 35 seconds
if stucked with adb side load thing ,..just press power button + down volume key for some seconds. hopw it solves the problem
I have a very simple solution. Not sure if it works on all devices but it worked on my `trio AXS 4G` tablet. I push a pin in the reset hole, which am sure all android devices have. That turned off the screen and all i did was turn the tablet back on and good as new all my files and app was there. P.S i had it plugged into a charger while doing this I`m not sure if that helped just thought i`d mention it.*
Tfunz
