How do I get rid of the circle icon with line through it at the top of my phone?
Re: how to get rid of circle icon with line through it at the top of my phone
It is a silent mode option, in this option you can set timing also (2-8 hours)to keep mobile in silent mode,after expiry of this time the mobile automatically sets to General mode.
This symbol means "Alarms Only". Either go to quick settings dropdown menu or the regular settings menu and tap the "alarms only" button to disable it.
Hi I am from Singapore I have the same problem with all of u out there am not sure how to off the WiFi calling button
i tried the volume thing but there's no "none, all, priority" options. i have a 4.1.2 android though. what do i do?
ever since i did the upgrade i now have an icon at the top of my phone that is a circle with a line through it and it's killing my battery and i have no clue how to get rid of it
I hane another solution for the the problem hopefully. If any of u have downloaded Samsung device solution and ****ed around w it than go back in to it turn all options off as it were when u first installed it. It worked for me and hope I can help.
Hi, please can you help me! I have on Samsung galaxy the circle with the line please can you help me off. Many thanks
Welcome.
None of the suggestions in this thread has worked?
Hi, please can you help me! I have on Samsung galaxy the circle with the line please can you help me off. Many thanksView attachment 357375
I tried the volume thing but there's no "none, all, priority" options or I don't understand how to do it. I know very little about phones. Maybe you can explain more. Sorry
At the moment I only can used phone by WiFi calling if I off circle back. Thank you for your help.
looks like problem with network, because network not available, couple days ago my phone was been broken I had problem with charging system. I think guy who fixing doing something wrong.
You should bring it back to the repair shop and ask them to reevaluate it.
You can also try a different SIM card, in case your current SIM card has failed. Ask your carrier about that.
Reactions: Laura Knotek
watertraveler
