How do I get the "Verizon Wireless" before calls off the phone?
Hi Jvanwinkle. I can help you with this issue. FYI - I have an LG G3 (after the April 2015 software update). From your Verizon phone, go to Settings, Sounds & Notification, Sound Effects, then uncheck "Sound When Roaming." This will fix that obnoxious "Verizon Wireless" announcement from your phone. Hope this helped!
Fixed it!! Thanks... this was set after an update, drove me crazy. Thanks Verizon for being the pig you are.
Well it is 6 years later that I am having this problem - and thanks Corey - your old message got mine fixed! :):):)
godef
