how fast should wi-fi hotspot tethering in 4G be? (17mbps speed)
Touchpaddle
491
9
how fast should wi-fi hotspot tethering in 4G be? When I checked using several speed test sites,
my Galaxy Nexus is getting up to 17mbps download speed from Verizon's 4G network. (usually
averages around 11mbps to 15mbps)
when I turned on hotspot, my PC and laptop is only getting 3mbps to 5mbps from the GN's
wi-fi output. (all in the same room... or even when next to each other) Is this normal?
Thanks! :)
Re: how fast should wi-fi hotspot tethering in 4G be? (17mbps spe
I get 10-12 mbps in my laptop with tethering from GN.
Already cancelled my internet service a month ago.
I tested mine not long ago with a 10 GB download. Speeds never dropped below 10MB and got up to the low 20s from time to time.
I should clarify that this was a tired tether. Wireless will probably be a tad slower, but I've never tried it.
Thats about the same as the wifi hotspot on my 4g ipad in the North Jersey area.
How do you do wired tether? I tried with USB cable and somehow there is no workaround with hotspot fee. With wireless tether, I am fine.
Not sure there's a non-root solution.
Question-
Does anybody's GN fail to send text messages/ receive calls after/during the use of a tethering app?
I'm on 4.0.4 leaked with the Wifi tether app pre110.
Tried different ones with the same results...
Have to reboot to get back to normal.
Question-
Never had an issue using the built in stock one on an unrooted nexus. I use a free tethering widget to avoid the fee. No root necessary
I use FoxFi, not rooted. I can send texts while I am tethered and after. I'm on 3G only here, too. Of course data gets interrupted while I send and receive texts but it picks back up right away.
Maxyguy666
