mouseglider
- Dec 11, 2009
- 462
- 25
- 0
I have never gotten more then 4 hours screen on time with any update or any custom rom. That is what I would consider heavy use. ;-)![]()
Then again I went on a carribean cruise for a week running bonsai 3.0. I put the phone in airplane mode and kept it inside our cabin and got 6 days. Yes DAYS on one charge.
So in my opinion battery life is directly related to screen on time and signal strength.
Right there should tell everyone with heavy battery drainage, that it is when the phone radio tries to connect or is connected to a weak signal will drain your battery. How much or how fast depends on the signal and how often things are updated. And when it is not connected and/or in the Airplane mode where the radios are not used or trying to search a weak signal, you will have GREAT battery life!
With that being said, if you have a ton of widgets constantly looking for data or even simply two apps like Twitter or Facebook that is constantly updating with a weak signal, you are going to drain your battery.
Now take another example of just the two apps Twitter and Facebook even with the same sync time with great signal and not so active Twitter or Facebook updates, your battery will last longer.
It is all in the setup and how you use your phone, so trying to compare two epics from two different users is almost a useless comparison. My wife uses Facebook all the time everyday all day, I use it once a week for about 15min each time - she has Facebook loaded with live widget updates - I only load Facebook itself when I want to use it with no widget updating in the background - who do you think is going to have the better battery life in just this scenario?
I started with DI18 -> EB13 -> EC05, and I would say each time my battery improved a small amount or stayed the same, but never got worse. But that was only after about a week worth of testing after each update. By that I mean, I don't even test battery drainage right away, because you are simply playing with it more than usual to either tryout/test new features. When you go back to normal usage, then you can test your battery drainage with a little more accuracy.
I get fantastic battery usage and consistancy for how I use it. And one last thing, all Samsung OEM batteries are not created equally, some are a little better, some are a little worse, so some problems may be the battery. I use four OEM stock batteries and three of them always sits in its own external charger and I rotate them on a pretty consistant usage pattern - trust me they are a little different, not by much, but still different.
