MikeLW1984
- Dec 28, 2015
- 68
- 0
- 0
No issues and has been on since Sunday. Easy install. I was worried about it being a difficult install but was really easy.
I wouldn't call it a polish, it's LOCA which stands for liquid optically clear adhesive. It's definitely different than a polish that actually hardens because LOCA stays in a semi soft state allowing it to be easily removed. Unfortunately the way these protectors are installed it would be very difficult to clean them before curing them.I'm guessing this "adhesive" is basically a uv gel polish. (I'm a nailtech) - I use this kind of UV light for my clients (on a bigger scale), so if you will cleanup the adhesive before you cure it, it should wipe right off. Then cure.
I have done it perfectly but do get the glue residue at the edges. Used to have it on the Note 8 as well.... Drives me mad but just keep on cleaning with a lens cleaner solution!
