[How to] 1-Click-Red cwm for Mac users (No bootcamp or windows required)*update 3/1*
Status
Not open for further replies.
SUCCESS!!!!!!! Vibrate and haptic back! Many thanks to you guys! I will look you up when I get the courage to flash froyo!;)
haha I'm sure we'll be here. Maybe there will be a different method for Macs, depending on how long it takes to build that courage ;)
anyone running superclean 2.7 or 2.8?? im on 2.6 using this method but just curious to see if i should update to newer versions. I noticed that some of my incoming calls go straight to voicemail. Anyone else with reception issues?
Flashed super frankenclean 2.8 and everything is working good so far. Unreal flashed it as well this afternoon, everything went smoothly.
Braydon:
Should of asked before I try this but will flashing this file wipe my data? Just curious..... I have made backups. Also you mentioned I wont be able to flash Froyo without flashing a different kernel. Would that stop me from being able to receive the OTA update?
Thanks!
Just flashed SC 2.8 Froyo without having to flash a different kernel and everything's works good so far. You should be good to go when the times comes.
Reactions: mouser991
Status
Lilrose
