- Feb 21, 2011
- 169
- 58
- 0
can I at least get my contacts back right now or no?
Do you have a gmail account? Is it set up with ichat?
Unreal check your pm inbox, or did you fall asleep lol
I have never used or set ichat....
DroidXcon mentioned you were working on a program for macs that is similar to odin...how is that coming?
I used the mac 1 click root and CWM for 2.1 and used it to install SC 2.6. Everything worked perfectly.
However I'm running into an issue trying to update to SC 2.8. I downloaded the file to my SD card and tried using the volume + power buttons which takes me into blue recovery, I try the update.zip and it says file not found. So I tried the 1 click CWM for 2.2 and it seems to keep saying error: device not found. SC 2.6 is still running great so im in no rush, but any advice would be appreciated.
is this something I should try too?
This is the link Droid posted earlier, you can try it again though. Did you get my PM?
I want to say that its people like Braydon and Droid X that make this forum worth while!
They both helped me through my struggles until my phone was fixed!
THANK YOU SO MUCH.....
THERE ARE GOOD PEOPLE OUT THERE...AND THEY ARE TWO OF THEM!
Had the hardest time trying to figure out how to get rid of the orange cwm and back to the red cwm. I happened upon this post and this has been a dream. It worked just as you posted. Now if someone would could develop a mac compatible odin, I would not have to run to my sisters house for the times I end up with a "Pretty paper weight".
Thank you so much for all your work.
DrX:
That link sends me to a download for a eBo1modem.tar file I believe. I placed the file on my card but cat find it with CWM. Do I need to rename the file to a .zip file and if so which option should I select in CWM? -apply sdcard:update.zip or -install zip from sdcard? I dont have Froyo, still running 2.1 just would like to get vibrate back.
Thanks you guys are great!
