When I use WinImage, Disk, Restore Virtual image to physical drive, there is no option to change to "all files", there isnt any files listed at all. The only box to check states "Include non removable hard disk(s). Also, which version of WinImage are you using? I downloaded version 8.5.
3A. PC Users:
- The usual program for this, Win32DiskImager, isn't working with this large file. So download WinImage, and under 'Disk' choose "Restore Virtual Image to Physical Drive." Change the files shown at the bottom to "all files" and select the file.
When using WinImage , after you select the restore to physical drive function it opens up the browse window to select the file, at the bottom right of that new window switch it from "virtual hard diks *.ihd" , to "all files"
