How to fix my samsung galaxy J7 inside screen without going to pay for it to get fixed?
  • Thread starter Android Central Question
  • Start date
A
my screen is not responding but i can hear my calls and stuff i think its the inside screen any advice on how To fix it without going to a place to fix it
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Welcome to Android Central! If the problem persists in Safe Mode (https://support.t-mobile.com/docs/DOC-30290), then it's a problem with the touchscreen digitizer. If you're handy, you can look up how to replace the screen yourself, but this means you'll still have to pay for a new screen, and then you'll have to hope that you do a good enough job that you don't damage something else. If you don't have any experience fixing phones, I strongly suggest you take it to a repair shop.
