How to get battery percentage next to battery icon?
zrxoa1
1,403
44
Is it possible to add the numeric battery percentage to the top of the screen?
acejavelin
1,935
27
It should show up automatically well charging on the lock screen, otherwise...
https://forums.androidcentral.com/e....kroegerama.android4batpercent&token=mWPkrcbn\
This will enable a small %% number inside the battery icon when NOT charging, it maybe sufficient and is easy and unintrusive or use an app like GSAM and get any number of icons in the notification bar or in the notification pull down
bafare
Active member
May 15, 2014
41
I don't think that's a deal breaker cause I just double finger slide down to check battery percentage.
Posted via the Android Central App on Moto X 2014/Moto G3/Moto G1/Lenovo Tab S8/ Lenovo Yoga 11
Sizzers
640
54
28
Also have a look at Battery Notifier BT.
I have the Pro (paid) version but the free version has what you're looking for as in my screenshot (the colour is customisable), although you cant actually place the percentage next to the battery. Has a great set of other functions as well and worth checking out.
Abdul Ali
