How to increase internal memory from 175mb to 1gb
my mobile LG P698 have very low internal memory can i make sd card as my defult memory to download apps to it????
plzzzzz help
The internal memory of my mobile(LG P698)_ is too much low , can i used my sd card for storing downloads directly .........
concentrate on my question////////////////////////////////
You do realize this is the V forum, right?
What info do you have for your phone? Size of internal storage, size of sd card, the amount of actual usable RAM?
There are several methods that can be used to help improve you app storage, etc. Depends on what your needs are.
Post info, and I'll look into it more for you.
I have 101 installed apps. I still have 112MB of internal storage free.
Use Link2SD. Partition the sd card with the ZenGarden recovery and reformat the partition to ext.4 with that same recovery. Do not make the partition larger than 2GB. 1.5 is optimal.
If you need more info, let me know by quoting this post.
Hey hi,
Do you know how to update rom for rooted mobile?
Please reply me if u know about it?
Dp you have a custom recovery installed?
If not, no problem, I can help with everything you need.
Let me know where your at with your phone right now (stock or custom ROM, rooted, stock or custom recovery).
tenho um LG P500 One com CM11 Kitkat 4.2.4 esse tuturial serve pra esse modelo e para a vers?o da ROM agrade?o pela aten??o : Cool:
I was going to say this needs to be cleared out because search engines point to it for a different phone model...
But its a nice monument to andyopie... *sniff*
umm guyz can you help me on something?
i just bought this O+ 8.33 android kitkat 4.4.2 and it has no 2nd partition and has only 124 mb internal memory .. how can i expand it ? the only app i can download is minecraft nothing else .... please pm me if you know how to expand ... my name on facebook is FRANCIS GUEVARRA ESPANYOL:'(:'(:'(:'(:'(:'(:'(:'(
tech gropse
