[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
miui u can change as well.....i love it. btw try this for me, now go back to your old wallpaper you had and see if it is transparent now. should be and u can have that wallpaper back
that did the trick... awesome!
back to the miui.... when I go to unlock, it is just one glowing circle that I drag to the little lock... and I missing something?
there should be 3 things with the glowing : a phone, a unlock, and text. if u drag either of those up or down it goes to that option.
weird.........thats not right. u r on 1.3 Kang Bang? maybe flash sbrissens mod. read this thread over at XDA flash that and u should be good to go. than u may have to reflash honeycomb theme, dont know why u wouldnt have that.
now that I think of it.... i think i disabled those other options when I had the original puzzle lock... maybe that is why??
Now I cant find where I disabled that at.... ugggg
That did it.... I did have to reflash HC as you thought. I thought the muiu lock screen had music controls on it? At least the screen shot in the op on xda did
Sent from my SCH-I500 using Tapatalk
Glad your good to go bro. also I downloaded the blue theme for dolphin hd and it fits perfectly. Only thing I miss is the smiley face on the keyboard.
I just flashed nitrohoneycomb, but I still have the keyboard from my last theme. Do I need to reflash my rom then the theme again?
sent from my kang bang fascinate
im sure nitro will release the honeycomb themed keyboard out soon to flash over maybe or you can check in /system/app if there two android keyboard apks and delete the one you dont want.
It is very odd that it did not cover the keyboard. You could also try switching keyboards Settings> Language & keyboard and see if that changes things..
Then I would try reflashing the theme and see if that changes the keyboard..
In the settings all it had was swipe keyboard, mtn gengerbread green, and samsung keyboard. I tried reflashing the theme and I still have the green keyboard.
When you selected the Input Method... was there a Swype, Gingerbread, or Samsung keyboard??
The Samsung keyboard is the one that may have been themed..
First one is theme and second is Samsung
I believe the swype keyboard is the same from 4.2.1. I have that keyboard available on my thread with instructions if you don't want to go through flashing the theme, ROM again.. :cool:
EDIT: Sorry to butt in...didn't realize you were talking about the stock keyboard..
I just upgraded to COMMROM 1.3 and I'm trying to reinstall the boot animation I had previously: Android peeing on Apple Boot Animation - JaeKar99
I tried manually moving the bootanimation.zip file back into /system/media but when I reboot there is no boot animation at all.
So I downloaded it again (for CWM 3.0) and attempted to flash it but it says "can't open /sdcard/download/AndiPee-Edify.zip (bad) Installation aborted"
I think there's something wrong with the file.. I have downloaded it twice now and get the same result.
stantn
