[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
im gonna flash ill let u know if i find something to fix the clock coming up cause i want that as well. you do the same
edit: its taking forever to boot up........took 4 mins to boot up, I have my clock working just fine however it is green and need to find that blue he used for it though. Have you tried changing the color than booting back up? thats how u had to do it for KB. Wish I could figure out the number for this blue lol anyone?
hmmmm.... not sure how to do this. is there a link to do this?
thanks bud!
Reactions: shoestring789
Just go into TSM--->status bar setting--->text color---->than pick a color make sure to click in the circle when u have chosen the color to make it take. than reboot. let me know if that works. I cant get the exact color yet lol.
Edit: Jae do u have the google shutdown ani as a zip?? thanks buddy
Reactions: JOrtenzi
I don't have TSM after flashing this any idea why?
If you are talking ComROM shutdown - Here it is.. it also contains shutdown sound.. - if you do not want the sound you will have to go to system/media/audio/ui and delete, rename, or replace the shutdown.ogg file..
Link
Reactions: bigjobber69
TSM is a modification of the framework files and when you flashed this theme it replaced those file(s) - with the themed files - nitro is not using TSM parts..
You can download and re-install TSM but it will 'untheme' parts..
It is one of those trade offs for function... nitro may include TSM parts as the theme develops..
Reactions: GalaxyNole
I still have all of my TSM parts bro....also thanks for the link Jae!
Never mind, I was looking for it in my apps but I found it in settings. BTW, the new MTM Blackout Blue keyboard is niiiice.
got it... thanks again boss
ok... another question...
my lock screen (I am using the ASOP, but I am having the same results for all of them) instead of being able to see my wall paper in the background, instead it is just a black screen.
Any idea as to why? And can I get it to show my wallpaper as the preview screen shots have shown?
Thanks!
ok jae and everyone else for this theme. i have rebooted 33000 times and the closet color i have gotten is 5678ae hope that helps you guys
Reactions: JOrtenzi
No prob man happy to help! not sure what the problem is with the background mine shows my background still, change your background to one of his that he packaged with the theme and try it.....maybe that will help. Im loving the miui lockscreen though, and hope that it will show missed texts soon like it does with calls. hopefully sbrissen fixes that...
which is the miui lock??
edit: ps... the packaged wall paper worked.... thanks AGAIN! lol
tsm parts-->lockscreen settings--->lockscreen style--->miui unlock. its awesome just make sure after u set it that then u go to custom app and route it to ur sms app of choice(handcent or stock or gosms)whichever you use.
are you talking about the 4 tab unlock? because that is the one where I get the TSM unlock also... i didnt get that on the miui unlock
miui u can change as well.....i love it. btw try this for me, now go back to your old wallpaper you had and see if it is transparent now. should be and u can have that wallpaper back
stantn
