How to remove camera shutter sound?
Should be under the camera app settings.
No joy.
No shutter sound setting any where.
I checked the app, I unchecked the app. Volume on, volume off. No change.
Anyone else with a Note 2 on Sprint with 4.1.2 stock, get this to work?
Sent via Note II
If the phone is rooted... goto root > system > media > ui
Under ui , rename the files shutter.ogg to anything eg shutter_no.ogg
do the same for camera...
Reboot....
Voila!!!! No camera sounds...
Enjoy!
Sent from my GT-I9500 (Hassan Khalid Malik) using Tapatalk 2
Reboot....
Enjoy!
I am not rooted. No intention to root this phone.
The search continues.
Sent via Note II
I tried that link to the apk app. It worked on my galaxy s4 but I had to switch back to the s3 and it won't work on the galaxy s3.
Any help would be appreciated. Thx! Also I have Sprint. Looking into switching to tmobile. If anyone has info on that as well I would be very grateful.
Open camera app. Menu key. Settings. Settings tab. Scroll all the way to the bottom. Shutter sound off. Arr you on the latest update
I think only some carrier versions have this.
Sent from my T-Mobile HTC One using AC Forums.
I've noticed on mine, if the phone is in silent mode, there is no shutter sound. Could be a quick work around.
I tried the app that was linked above on my GS4 and it worked like a charm. Download it, open it, and check the box next to "Disable STREAM_SYSTEM_ENFORCED."
I also want to confirm that the Verizon version of the GS4 (which is the version that I have) doesn't have "Shutter Sound" listed as an option under the camera settings. Hence, the need for the app.
Wait a minute. My s4 doesn't have a shutter sound because I have it in vibrate mode and that turns of any notification sounds even the shutter sound. So why on earth are people download apps for their phone when the shutter sound can be turned off by muting the notifications sounds.
Sent from my GT-I9505 using Tapatalk 2
what else does this app affects on?
otr than cam?
btw...thx a lot...just want to understand the side effect of the app
On a samsung S3 how to turn off the shutter sound. I have tried everything and can't get the sound off any help at all would be nice thanks:)
One solution I'm surprised nobody has mentioned that should work on all carriers--install a 3rd party camera app and just don't use the original app. They ALL should have the option to silence the shutter sound. There are several in play store.
Do I need a specific root explorer to use this? I tried through es file explorer with no luck. Any help would be appreciated.
Ashok Dharshan
