How to remove camera shutter sound?
There is an entire thread already for this, why can't people search?
Free tech support is an "externality," in economic terms. "Free" as in beer. And someone else is doing the brewing.
___
Posted via mobile.
I don't have the sound option on mine either and I'm on Telus(Canada).
I did switch to Camera ZOOMFX and have that option.
Try a simple solution put your index finger on the speaker at the back of the device and it will almost mute the sound
I have a Verizon phone and don't have the option to silence the shutter sound. I made an easy Tasker profile that solved the problem. Works like a charm. Profile- when camera app is loaded, Task- shift to silent mode and when leaving camera app, return to normal volume.
How to remove camera shutter sound? Thanks! :)
When I clicked on the link a pop up at the bottom came up that says:
This type of file can harm your device. Do you want to keep it anyways?
Should I be afraid? I've only had this phone for 4 days. I don't want to screw it up. I just came from an iPhone 5 and I really liked the ease of silencing the shutter on it.
Hi
EnforcedStreamSilencer .apk
This did not work in Galaxy Note 3 (Australia Version)... Camera shutter sound still occur.
Thank goodness. The link worked for me as well. S4 on Verizon
kctraci1
