How-To repair your bootloader after using the 2.1 RUU
it says file location not found i have it in a folder labeled android stuff
i had some problems on my desktop getting command propmt to work. This is what i did go to android sdk open the sdk setup.The window that opens should say sdk location(look at pic above) copy and paste that to command propmt add \tools to the end of it should work.hopefully.
this is what i get
C:\Users\Will>C:\android-sdk-windows\tools
'C:\android-sdk-windows\tools' is not recognized as an internal or external comm
and,
operable program or batch file
this is what i get
and,
when you open command propmt type cd\android-sdk-windows\tools do you get same thing.
after the last step to reboot my phone rebooted with that screen
If you mean the green/black menu with options then thats the recovery img that you wnated should mean it worked id make a nadroid backup and i think your good to go can flash a custom rom now.
tonga94
