How to reset 5.0.2 MotoG , lost Display-Lock-pattern
hoffmanns5
I want to reset my android to factory settings, because I can't remember the display-lock-pattern.
What I did was: shut down the smartphone. Boot with volume up and volume down and boot held together. Then there was a screen
Normal powerup / Recovery / Factory / Barcodes / BP Tools / QCOM.
I scrolled to Recovery with Volume down and then Volume up to select.
Then I see an opened android logo with a red triangle and "kein Befehl" which means "no command".
volume up or down doesn't change anything.
Also selecting "factory" only gets me to the booting procedure and to the locked starting screen.
Do you have an idea?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,618
4,760
113
Welcome to Android Central! Instead of trying to do a factory reset, what happens if you fail the pattern unlock enough times? Does it ask for your Google credentials?
Abdul Ali
