[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
Re: [How-to] Revert to LS670V9, after installing OTA LS670VC/VD,
I think you have the new LCD. You should revert to LS670ZVD. Can you still do that?
Doesn't look like it. Phone doesn't boot up now and is not recognized by PC to do anything else.
Can you boot into recovery?
Pull USB cable, remove cover/battery, wait 5 seconds, replace battery/cover, simultaneously press and hold [Power][Vol Dwn][Home] until Recover shows up, release buttons, replace USB cable.
if you hold down vol down home and power for a few sec it will turn on and boot into recovery. you can now flash it. i recovered the first two phones i flashed with this method
I tried it I followed step-by-step, but after step p) my phone rebooted and is now stuck on the Android screen, its been there for 3 hours now, Help please!!
update: I read some of the posts and I can boot into recovery. Should i pull the sdcard and load an update.zip onto it? and if so what should it be? or should i do the factory reset?
Update 2: I tried to factory reset, but it just wiped data, but it booted to android, I just get the spring ID screen, and can't do anything. My phone is about a year old, it was rooted, and my wife accepted an OTA update, and lost root. I'm trying to get it rerooted and fixed so it can work. I can boot into recovery it says "Android system recovery <3e>" the only other thing I can do is reboot, install update.zip, and wipe data/cache.
I tried to rerun the KP500 and got the fatal error message" Here is the log...
15:41:10 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
15:41:10 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
15:41:10 : Start Date : 2011-09-22 15:41:10
15:41:10 : -------- Buyer Test mode ---------
15:41:10 : [C:\ProgramData\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
15:41:10 : RemoveDirectory1 Error(145):C:\ProgramData\LGMOBILEAX\Phone\BIN
15:41:10 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
15:41:10 : *****CheckOS Start********
15:41:10 : Microsoft_Windows_Vista Home Edition_
15:41:10 : *****CheckPCSyncPrograms Start*****
15:41:11 : PCSyncPrograms Not Found
15:41:11 : SetEmerModeAT()
15:41:11 : _IsConnectedPhone Call
15:41:16 : _IsConnectedPhone(1)
15:41:16 : 0 - NotConnected.
15:41:16 : 1 - Normal connect success
15:41:16 : 2 - Emergency connect success
15:41:21 : Checking the connection with the cell phone...
15:41:21 : dwWaitResetTime(40000 ms)
15:41:22 : Phone Mode(1)
15:41:22 : *****GetPhoneType Start*****
15:41:25 : Phone Type : CDMA
15:41:25 : *****Start GetPreviousStep*****
15:41:25 : _GetPreviousStep(dwStep:0xffff)
15:41:25 : _SetPhoneNumber retval=1
15:41:25 : *****GetPhoneModel Start*****
15:41:27 : *****GetPhoneBinaryVersion Start*****
15:41:27 : Phone Bin Version : LS670ZV9_20
15:41:27 : *****Get ESN / IMEI / MEID Start*****
15:41:29 : ESN/IMEI/MEID : A00000284DE851
15:41:29 : *****GetPhoneNumber Start*****
15:41:32 : Phone Number : A00000284DE851
15:41:33 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A00000284DE851, Model :
15:41:33 : *******CheckBinVersion***************
15:41:33 : New Bin Version(LS670ZV9_20), Current Ver(LS670ZV9_20)
15:41:33 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
15:41:35 : _GetAuthMark : wAuthMark(27987)
15:41:35 : Wait 3Sec
15:41:41 : _SetAuthMark Ok : wAuthMark(27987), PhoneMode(1)
15:41:41 : *****Start _GetBatteryLevel*****
15:41:43 : Battery(5)
15:41:45 : ResetPhone...
15:41:45 : Checking the connection with the cell phone...
15:41:45 : dwWaitResetTime(40000 ms)
15:42:15 : _IsConnectedPhone Call
15:42:21 : _IsConnectedPhone(1)
15:42:21 : 0 - NotConnected.
15:42:21 : 1 - Normal connect success
15:42:21 : 2 - Emergency connect success
15:42:21 : Phone Mode(1)
15:42:21 : m_dwBootWaitTime(35574)
15:42:21 : Checking the connection with the cell phone...
15:42:21 : dwWaitResetTime(30000 ms)
15:42:51 : _IsConnectedPhone Call
15:42:56 : _IsConnectedPhone(1)
15:42:56 : 0 - NotConnected.
15:42:56 : 1 - Normal connect success
15:42:56 : 2 - Emergency connect success
15:42:56 : Phone Mode(1)
15:42:56 : Call _ModeOffline()
15:42:57 : *****CheckPCSyncPrograms Start*****
15:42:58 : PCSyncPrograms Not Found
15:42:59 : CLGMobileHttp Class ?Ҹ????.
15:42:59 : CLGMobileHttp Class ?Ҹ?...
15:42:59 : ****************CheckAndDownload********************
15:42:59 : ******Extract Start LS670ZV9.cab*****
15:42:59 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
15:42:59 : ExtractInfo Error(0)
15:42:59 : Extract cab file error.
15:42:59 : [C:\ProgramData\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
15:42:59 : RemoveDirectory1 Error(145):C:\ProgramData\LGMOBILEAX\Phone\BIN
15:42:59 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
15:42:59 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
15:42:59 : Page_Error ?κ??Դϴ?
15:42:59 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
The File is there, and it went through the process the first time...Thanks for any help
I downloaded the LG Mobile Support tool but it doesn't show the LS670 under the Sprint option. I also downloaded the drivers manually and when I point Windows to them it doesn't work. What do I do?
OK guys, I need help. Followed instructions everything was going good until i used the lg updater to revert back to v9. I am using screencast because of the newer lcd but since i ran the lg updater the phone doesnt do anything. Screencast cant even pull it up anymore. Please HELP me I cant afford to buy a new phone. My mistake was updating to that POS zvh. It caused hypersesitive touch screen and I was unable to do anything because touching once caused multiple touch sensations. LS670 BRICKED!
The LS670 drivers are available here:
http://www.lg.com/us/support/mc-support/drivers/LGLS670.zip
Install all three of the drivers.
You only need to install LG Mobile Support tool, you don't need to run it directly. The Mobile Support Tool is available here:
http://csmg.lgmobile.com:9002/client/app/B2CAppSetup.exe
To get past the Sprint ID screen, you just need to let Hand Free Activation finish and choose a Sprint ID. If you don't want to do that or don't have a data connection, you can just press the Voice Command button on the side of the phone, aboe the camera button, then say "Settings" or "Wifi settings"
First thing you should do is turn on USB debugging.
Then you can use root using the appropriate instructions for the version of Android you installed (ZV9 or ZVD)
If you have the new LCD, you should revert to VD. Boot into Recovery by removing USB cable, pulling battery/cover, wait for 5 seconds, replace battery/cover, simultaneously press and hold [Power][Vol Dwn][Menu] until Recovery comes up (will be blank screen for you), then use KP500 to flash the VD cab file instead of V9.
ok well when I have to enter the file name do I format it as the same as the ls670zv9_20 (ls670zvd_20)?
Just use all the replacement steps listed in the reference section:
Substitute these steps to Force Flash VD
f) download VD cab (LS670ZVD_12.SD_12.P60675.cab) (Alternate download)
h) ren LS670ZVD_12.SD_12.P60675.cab LS670ZVD.cab
i) expected checksum - 6bd5faf21acb951abb7e2c6e8ce39e7d *LS670ZVD.cab
n) cab file - LS670ZVD.cab
o) version - LS670ZVD_12
Ok so I got it up and running with the vd now how would I go about getting root access and maybe a custom rom? I liked GB but it caused hypersensitive screen issues. Anything you can recomend to use that doesnt take up tons of space. These things arent that great on space.
In the beginning of the how to root zvh post, there are links to 2 methods to root ZVD. just choose which one you prefer. The first one (gingerkernel) is more of a one-click I don't want to know what is going on solution.
When I try that, I still get no video on the screen. The backlight comes on, but I have a black screen.
What happens when you connect the phone to your PC and type "adb devices" in a command prompt open to your adb tools directory?
I believe all you really have right now is V9 recovery and V9 android on a new LCD phone. Everything is probably running find, you just can't see anything on the screen. If this is the case, it can be recovered from, just don't get anxious and do anything crazy w/o being instructed to do so.
Here's what's displayed:
C:\OptimusRootZVD>adb devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
A0000028EF4E1A recovery
Your PC can communicate with your phone. This is good. Just run KP500 substituting the VD cab file (in the reference section). Your phone should be booted into recovery when you run KP500. This will put VD android on your phone and when you boot into Android, you'll see stuff on the screen again.
Downloading now. Once I'm back up, I hope to put gRom 1.1 on. HOPE...
If your end goal is gROM, make sure after you get VD android on your phone, you root VD android and put V9 stock recovery on your phone. Don't assume it'll still be there because it is there now. There's a good chance it will, but it might not, and you don't want to go through the downgrade again just to skip a 3 minute step.
I have applied vd and have screen display (YES!) but comes to android system recovery <3e> with an error Finding update package...
E: can't find command file CACHE: recovery/command
Installation aborted. no valid image in cache.
snacks1233
