Yes, this is what I did with my phone.Thanks! has anyone tried this yet?
Get root.
Open this apk and install it.
Open up root explorer and rename the secsms.apk or whatever it is to secsms.bak to disable it.
Enjoy.
you have to be rooted?
Here's a link to the one that works....http://concentriclivers.com/android/Messaging-4.0.3-8.apk. If you open it up in the TW browser it should start downloading it for you.
I'm using the one above because I like the stock messaging app.
Just make sure you disable the TW messaging app.
I would think you would want to disable the old sms program. Did the file just overwrite the old one for you?I'm not rooted and it works fine for me.
At any rate you should root anyways because it's easy and fun. Chicks did guys who rooted. You may be able to help ROOT them in return (if you catch my drift).
My friend with a stupid iPhone sent me a MMS. Doesn't seem to work with this method. Anyone experience this? My fiance can send me pictures find, but she's android.
