[How-To] Root, Custom Recovery, NANDroid Backup
I have the Optimus Slider VM701 and have followed the instructions on page 1 and the YouTube video. After I press the Enter key, the message reads "Daemon started successfully" but goes no further. I have the latest drivers installed, Debugging, User Development and Charging Only selected. I have the LG Mobile Drivers 3.06 installed and version 2.3.4
Any suggestions?
i have rooted and set up to recovery and it all worked perfect but when i tried to back up it says; Error wile makeing a back up image of /sdcard/ .android_secure ! if i restore will it still work if not what do i have to do to correct this
I just got this phone today and rooted and flashed custom recovery without any problems. Any chance someone could post the stock recovery in the event the phone needs to be returned?
If you followed the directions then you should have made a nandroid backup... which will take it back to stock with only ROOT access.. if not... then the stock ROM is located in the forum.. I don't have time to link it right now.. just search it
No no, I didn't mean the stock ROM, I meant the stock recovery image that came with the phone. Someone had to have pulled that.
you were supposed to do it your first time in recovery. You cant pull a recovery off these
the enter key doesn't work in terminal emulator. i tried hacker's keyboard and gingerbread keyboard and they don't work. any idea? i'm tryin 2 install a custom recovery.
Are you hitting the "ok" button or the "return" button?
Yes return is enter on a PC but on these phones OK is enter
Sent from my LGL55C using Android Central Forums
Did you install a custom ROM? What phone do you have
GUYS I REALLY NEED HELP! My phone isnt recieving, sending texts or getting a 3g connection. I cant call or anything! i am running stock rom now and nothing has changed. it will randomly work (mostly when i turn it on) and then nothing! . This is my primary phone and dont have money for another one. I cannot go much longer without a phone for my family to get in touch with me. IF ANYONE HAS ANY INFORMATION TELL ME PLEASE! I am virgin mobile also. PleasE!!!
You are probably going to have to call virgin mobile and talk to their customer support about your problem. It sounds like you have a bad phone.
Also posting the same message on multiple threads is annoying and probably against the rules and could result in your being banned.
This is my first time trying to setup a recovery on my Optimus V. I am running through the steps on this thread and so far so good. But, now I am getting an error when I am entering the commands into the terminal:
su
mount -o remount, rw /system
cp /sdcard/flash_image /system/bin
cp: not found
As I said, I am new to this. I have tried and retried entering the text a number of times. Can someone tell me what I may be doing wrong?
su
cp: not found
Make sure you unzipped the flash image.zip file. Make sure you have copied the flash image file to the sdcard. Make sure the file is named flash_image not flash_image.zip. Make sure you have unmounted the sdcard from your computer.
Thanks for this, the recovery works great.
I really wish CWM recoveries came with adb enabled... :(
john_russell
