How to Root
Status
Not open for further replies.
Device not found after reboot
Hi, I am having similar error as laxguy - error: device not found after the reboot.
After the reboot, the media sync is running, and I don't know how to disable this function. I also tried the new code you just uploaded, but still gives the same error.
The files, such as superuser.apk, are not present in system/app right now.
I had the superuser app which I downloaded from market. I reinstalled it tried it again but still no luck.
I would appreciate if you could help me out.
Thanks a lot.
After reboot don't hit any key pull down notification window hit the sync notice and it will give you an option to disable....also do not mount the sd card.when its ready hit any key
Thanks a lot.
Sent from my SCH-I500 using Tapatalk
Very new here.
I followed directions and thought it worked. Phone reset and rebooted.
I unlocked and tried to download super user but that failed after install. Said a bin needed to be flashed in recovery. Not sure what that means.
I uninstalled superuser everything seems to be working fine.
Is it safe to try this again? Did it root? Im not sure what to do from here.
Edit*** Looks like the same thing that happened to HJW*****
Very new here.
Grab the download from method number 2
http://forum.androidcentral.com/fascinate-roms-hacks/53950-how-root-dl09.html
follow the same instructions, yes it is fine to try again
Ok, it was great until the rooting, but now I found my phone a little buggy. Sometimes the phone doesn't wake up by the right key. I had to remove the battery and reboot twice.
I installed the SetCPU app, but could that be the problem source?
yeah, because rooting is nothing more than moving files so that permission are available to you . it serves no active function. so if thats all you did than that most likely the source of your problem
no problem, but trust me both method 2 and 3 are really easy . but let me know
The rooting isnt really a problem, if its just one click im fine. I did that on my d2g, but when it comes to roms, I have a tendency to **** up phones (my old d2g ;P)
Fortunately it's much harder to completely brick a phone doing an installation of a custom ROM than it actually is to install one. I don't think I've ever heard of anyone permanently bricking their phone this way, it's almost always recoverable.
Alright, as long as like something happens and I can fix it without having to be scared going to the verizon store just to tell them that they cant fix it or some stupid ass thing, Im fine. Im heading out. I might talk to u more tomorrow about this. Im really just curious for the speed differentials with/without bloatware, and the sexy black notification bar. Other than that, I have no need =P
I feel so lost. I clicked on start_root and it said it was complete but now what? Where do I find directions for what to do next?
Status
visionarysearchist
