[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
yes i did pull the battery and as always, left it out for at least 10 seconds. (old electronics rule of thumb).
well it worked on the 5TH try, i'm not sure what i did wrong but YESS!! FINALLY MY PHONE IS A FREE MAN!!!! thanks sooooo much to everyone who contributed to this!!!!!!!
this is what i get held up on after i type .\ginger
Sogone, I had to try the process 5 times before it worked. After each try I restarted my computer, powered off the phone, removed the battery and tried again. Not sure why I had to do this but my phone is now free.
most times i see that happen is with windows 7, which you have to do the above until it works, or in some cases revert back to VD (see signature-ROM one) then try that way., each time it fails you have to restart your phone (may fail up to 10 times trying)
Newb question I know, but I don't know what to look for after each step, how do I know if I'm rooted now?
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Justin>cd c:\optimusrootzvd
c:\OptimusRootZVD>adb shell
rm -r /data/local/tmp
mkdir /data/local/tmp
exitrm -r /data/local/tmp
exit
c:\OptimusRootZVD>adb push gingerbreak /data/local/tmp/gingerbreak
111 KB/s (16830 bytes in 0.148s)
c:\OptimusRootZVD>adb push su /data/local/tmp/su
545 KB/s (26264 bytes in 0.047s)
c:\OptimusRootZVD>adb push busybox /data/local/tmp/busybox
1245 KB/s (1926944 bytes in 1.510s)
c:\OptimusRootZVD>adb push Superuser.apk /data/local/tmp/Superuser.apk
1445 KB/s (94728 bytes in 0.064s)
$ cd /data/local/tmp
cd /data/local/tmp
$ chmod 777 /data/local/tmp/*
$ ./gingerbreak
./gingerbreak
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Detected Froyo!
[+] Found system: 0xafd14129 strcmp: 0xafd1cb9d
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000142a8
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 0066 GOT start: 0x000142a8 GOT end: 0x000142e8
[*] vold: 0066 idx: -3072 fault addr: 0x000131d8
[+] fault address in range (0x000131d8,idx=-3072)
[+] Calculated idx: -1996
[*] vold: 1122 idx: -0001996
[*] vold: 1122 idx: -0001995
[*] vold: 1122 idx: -0001994
[*] vold: 1122 idx: -0001993
[*] vold: 1122 idx: -0001992
[*] vold: 1122 idx: -0001991
[*] vold: 1122 idx: -0001990
[*] vold: 1122 idx: -0001989
[*] vold: 1122 idx: -0001988
[*] vold: 1122 idx: -0001987
[*] vold: 1122 idx: -0001986
[*] vold: 1122 idx: -0001985
[*] vold: 1122 idx: -0001984
[*] vold: 1122 idx: -0001983
[*] vold: 1122 idx: -0001982
[*] vold: 1122 idx: -0001981
[*] vold: 1122 idx: -0001980
[*] vold: 1122 idx: -0001979
[*] vold: 1122 idx: -0001978
[*] vold: 1122 idx: -0001977
[*] vold: 1122 idx: -0001976
[*] vold: 1122 idx: -0001975
[*] vold: 1122 idx: -0001974
[*] vold: 1122 idx: -0001973
[*] vold: 1122 idx: -0001972
[!] dance forever my only one
# mount -o remount,rw -t yaffs2 /system /system
# cd /data/local/tmp
cd /data/local/tmp
# cat su > /system/bin/su
cat busybox > /system/bin/busybox
cat Superuser.apk > /data/app/Superuser.apkcat su > /system/bin/su
# chmod 4755 /system/bin/su
chmod 4755 /system/bin/busyboxchmod 4755 /system/bin/su
# exit
exitexit
exit
c:\OptimusRootZVD>
looks like you're rooted.... # line command is a superuser (or rooted) command line - i sees it.
when i get to step 11 i get "cannot create /system/bin/su: read-only file system"
went throught gingerbeak ok and everything else
where am i going wrong?
rm failed for /data/local/temp, No such file or directory .......I'm assuming this means the directory doesn't exist I looked through my phone using manager and didn't see it, do I need to create the directory? This is my first time using adb someone please help?
just try it again. im kind of a newb and i got it after finally installing the LS670 drivers. not just the LG ones. pull battery after each time you try. the third time i got it with no issues.
/data/local/tmp
not
temp
I've read, re-read, and read the instructions again (and a few dozen other posts on the topic)... I think I'm ready to root!
(The first time is always scary, no?)
My one newb question before pulling the plug on Sprint ID forever (thank you, lord) --
Do I need to backup anything before rooting? I see that Titanium Backup is recommended, but works only for non-carbon backups after rooting (and is not a replacement for nandroid). I'm also aware of the sticky post on reverting to stock and other posts for reviving a bricked device. And I don't really care about any of my current applications, saving SMS records, etc.
Hypothetically speaking, if the root fails for whatever reason (let's just say I didn't chmod correctly) what happens if I just decide to forget it? Will my phone work? Will I need to "undo" some part of the process? Am I screwed big time bad?
Many thanks to the OP, DroidXcon, and everyone else for the helpful posts. Hopefully many more thank-yous forthcoming when the root is complete. :)
I have a semi auto root method, it will require only two commands, are you interested?
and you dont really need to back anything up, you can always use mybackup pro if you purchase it. but you shouldnt really lose anything
Reactions: blackops1125
Good thread! like you, I am new to this before I jump in I have been reading as time permits. Seems like a great number of members trying to help out, thanks to all. Before I root I am going to read more so I can get a better handle of the process ;)
Vette
dumpsterrentals80
