[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
what if you have a Mac? will all of this work the same? is there another thread for rooting on a mac?
thanks
I've read thru this thread and saw 3 postings about this issue but didn't see an answer.
Optimus S (Android 2.2.2)
Kernel Version 2.6.32.9
SW Version LS670ZVD
I get to ./gingerbreak and it just sits at the flashing bar.
I have tried it 7 or 8 times (removing battery between attempts). No change "Insanity: doing the same thing over and over again and expecting different results" - Albert Einstein
$ chmod 777 /data/local/tmp/*
$ /data/local/tmp/gingerbreak
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Detected Froyo!
[+] Found system: 0xafd14129 strcmp: 0xafd1cb9d
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000142a8
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 0065 GOT start: 0x000142a8 GOT end: 0x000142e8
Any help would be appreciated :-)
Just wanted to give an update incase anyone else is having similar issues to the above.
1) Make sure you have a MicroSD card installed (I don't know if this is related but after I installed the card GingerBreak worked flawlessly.
2) Again not sure if related. But when I got to the point of executing gingerbreak I unlocked the screen lock slider. (I think the issue was #1 but who knows)
Hope this helps others.
Yes, you MUST have the sd card inserted in your phone for this to work
Could someone TeamViewer me please, I have tried so many times and can't seem to get this to work.
im sure itll be fun but id like to root my optimus :). I have VMware Fusion where i can run windows but this isnt working for me ha
Sorry im not sure why my messages are being sent to you... would u happen to know how to root n lg optimus s 2.2.2 zvd.. for a beginner?
So I went through the guide. I am a pretty new noob at all this. I did do revert to V9 with the help of the forum. But I am not sure if I am ready to try this. I do second the video thing. Reading it. I always miss a step or screw something up. But if I can see how to do it. Makes me more confident. So if anybody got some time I know I would appreciate it. either way I love this site. It totally saved me with my Optimus.
And now I read gingerbread is coming out end of this month should I just stick with the V9 till everything gets sorted out with the root for ginger?
thanks
i get an error when i reach step #11...it says "cannot create /system/bin/su: read only file system"....what did i do wrong?
read only fs
Sounds like the file system isn't mounted properly, I would double check step 9
Johno
