[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
ok im stuck these were my steps i have usb debugging on and unknownsource app install on also i turn on usb storage when i plug it into the computer after i plug it into the computer it does the installing drivers thing which i downloaded from lg but when i start using the command prompt i change it to extracted folder file(step 2) then type adb shell and it says "error: closed"
Make sure you turn off usb storage Try again......
Question about the nandroid backup. I followed everything you said, and installed the Xionia CWMA recovery kernel.
I don't see an entry on the recovery console for 'backup and restore'
Just the following:
reboot system now
apply sdcard:update.zip
wipe data/factory reset
wipe cache partition
What am I missing?
Just the following:
reboot system now
What am I missing?
Reflash the Xionia recovery. Make absolutely certain that you rename install-recovery.sh as stated in the Xionia flashing instructions.
Just the following:
reboot system now
What am I missing?
Thats the stock recovery....You need to try pushing the Xionia Recovery kernal again make sure you have a # in the abd shell and not $ or it wont work....
Sent From My Super Awesome Optimus S Via TapaTalk.....
Here's what I did.
So how do I change from a $ to a #?
Thanks so much for your help with this mid-forty's noob.
Oh, and I assume I'm rooted. How do I check that as well? LOL
Listen to Drewalton. I'm probaly wrong....Just trying to help...Sounds like a better answer anyway........:)
Here's what I did.
That Drewalton can help you with not sure how to get # without rerooting through cmd command on the P.C....or you can download a terminal emulator off the market and do it that way if your rooted itll already have the #.
To access a root shell, execute the "su" command (without quotes) in an ADB shell.
Also, don't actually type the "#" or "$" symbols. Those are simply there to denote that the command specified should be run in a root shell.
Cool, now I'm in pursuit of a nandroid backup. I'm going to post all the mistakes and lessons learned when it all works. Thanks again.
So Dre, I have Superuser as an app, but I can't use the su command after the abd shell.
Where do I go from here?
Being able to have done that from the laptop would have been nicer.
But it works.
Thanks!
So you got the recovery installed then?
Nevermind got your message...Happy to help someone in need....Enjoy your rooted optimus....
One last thing always make a nandroid back prior to flashing a new rom or something unsure of. You thank me again later....:)
DannyTG
