[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
Re: [How-To] Rooting LS670ZVD with GingerBreak (no reverting and
ok, i must be completely dumb, or really tired i have search for days for the root solution to my lg and finally stumbled across this and i can not follow it im lost on where to the the files how to run it and my eyes are killing me i think i need help lol
Thanks d00dz! :D
Im stuck at fire up terminal (cmd.exe) I know thats some black matrix stuff but how do I get there (obviously not as pc friendly as I thought I was )
Type cmd exe in your search window on your pc...Its a command prompt.....
Sent From My Super Awesome, Over The Top Optimus S.........Tapatalk......
inside your start menu under the accesories folder, there's a command prompt icon.
tried this once but used the wrong custom recovery. i feel a bit more confident this time around. i can't follow directions and didn't read all the way through
Great work. Thanks alot for making it public.
One question I have though and I see this on alot of different sites for rooting all kinds of different android phones, what's the advantage of doing the root from command prompt vs. the different one click rooting tools available?
In other words, why would anyone bother with a long tedious error prone method when there is the one click methods?
The manual root method forces users to learn how to use various console commands, which is useful for when you flash a custom recovery image as well as various other system mods.
[+] Detected Froyo!
[+] Found system: 0xafd14129 strcmp: 0xafd1cb9d
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000142a8
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 0065 GOT start: 0x000142a8 GOT end: 0x000142e8
[*] vold: 0065 idx: -3072 fault addr: 0x000131d8
[+] fault address in range (0x000131d8,idx=-3072)
[+] Calculated idx: -1996
[-] sendmsg() failed?
[*] vold: 2584 idx: -0001996
[*] vold: 2634 idx: -0001995
./gingerbreak[-] sendmsg() failed?
LykeXY23: pull your battery, reboot and try again.
Jaysmyhero: do the same as above. If you still can't do it, try using Gingersnap.
I'm such a noob, but even I could understand this! And I'm 10! But that doesn't mean it worked for me xD. But anyways, ProgrammingGod alert!
LykeXY23
Please give us some more information! Like does your phone boot up normal? How are you trying to root? How many times have you tryed this method? Have you tryed the gingersnap method? Are you running LS670ZVD? Is your SKD Tools (adb shell program) installed correctly on your PC? Did you download the drivers for your phone to you computer? Did you download LGMobile updater? We need more info so we can better help you get this done. The more info we have the better we can help you!
nirmalafoundation
