[How To] Unroot and return to stock [RUU Method]
Is there a "true" step by step instruction somewhere to help me root my Evo 2.3.5 4.67.651. Everything I've found just takes me in circles. Is there instructions that assume I don't know ANTHING about rooting? HELP!
Doesn't work.
Just says that it is the wrong RUU and to get the right one. Tried a few. Not sure how I'm supposed to know which is the "right" one.
I have just one request.. I am in need of the RUU File for my HTC one sv for BOOSTMOBILE, USA
HBOOT -1.01.00
RADIO-1.12.50.0115
openDSP-v7.2.0221.1123
This would help me in a great way guys......
Running a RUU is very easy. If you are s-off you can run any RUU foe that device. If your s-on you will need to run the version equal to or newer firmware version , you can not go backwards. also if you have a unlocked bootloader you must relock before you RUU
I need the RUU file for HTC One SV for boost mobile I found it once but theyre on my old computer in michigan i live in virginia no suggestions on any other methods to fix my phone please this is the best way to restore to stock I currently have no operating system currently on it the dalvak and cache have been cleared already please help me email mail me at alexander.salazar17@gmail.com with the file or a link in desperate need of the file i havnt been able to use my phone in weeks
I only get a message saying the main battery is below 30%...the phone says its @ 95%. I am rooted using aman_ra and mikG3.11 Any suggestions? Also I'm on a windows 8 pc if it matters.
I used the process yesterday to get the stock ROM back on my EVO 4G so I could get it working with ting. I could not get it to work with windows 8.1. I kept getting "usb connection" error message. When I used a windows 7 it worked the first try.
I made the mistake of rooting my Evo Design 4G with CWM and I can't un root it. It looks like when I flashed the 1.10.653.2 by adding it as PH44IMG.zip to the SD root that CWM is gone. The phone doesn't boot into CWM now it goes to HBoot. It is still rooted and the current rom isn't running well as far as my 3g settings. It acts weird now and I just want to go back to stock. Before the root, I could sync with HTC sync on the PC and now it won't sync at all. The PC sees the phone as a portable media player and I can open the SD card. I have tried the above method using RUU_Kingdom_ICS_35_S_Sprint_WWE_Boost_1.10.653.2_Radio_1.11.00.0418_2_NV_Boost_3.42_0418_PRL61007_release_262178_signed. My phone shows 1.10.653.2 Release keys.
I run this RUU and all goes well and then I get error 140 wrong boot loader and the exit button. Any insight as to what I can do to fix this is appreciated.
Note: now instead of 3G network it shows EvDo and my mobile reception is poor compaired to pre root.
here is the fastboot showver all I got.
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.32.0000
(bootloader) version-baseband: 1.11.00.1116
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 2.12.651.5
(bootloader) serialno: HT27BMB01769
(bootloader) imei: 353171050212838
(bootloader) product: kingdom
(bootloader) platform: HBOOT-7630
(bootloader) modelid: PH4410000
(bootloader) cidnum: SPCS_003
(bootloader) battery-status: good
(bootloader) battery-voltage: 4069mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-22b8e060
(bootloader) hbootpreupdate: 12
(bootloader) gencheckpt: 0
i hav rooted my htc desire 820. it struck at boot logo.. it is saying that no os installed... i need help........ unrooting and restoring my phne back.
my phones details are: HBOOT - 3.19.0.0000
RADIO - 01.01.010_U10305041_08.01.50512
OS - 2.10.720.4
eMMC - boot 2048 OC
Prince08900
