[How To] Unroot and return to stock [RUU Method]
I don't know what else to do can any one help me. I had it rooted and did a full erase i though that would fix it and no luck. I did everything here and I have done it at least 20 times and still no luck made sure it was the right ruu and nothing can any one help.?????
Tattrpuff, thanks for the guidance. I successfully applied the Simple Root method, RUU'd back to an unrooted EVO and OTA'd all the way to FROYO. It was time consuming but rather painless. Thanks again!
Did you use the latest version of Simple Root?
I have unrevoked3 installed and can't RUU. Was that your situation?
Did this, worked perfectly, thanks so much
Really didnt need root and just like doing OTA when new updates hit
For those who used the unrevoked3 method... you just need to follow exactly what he said above.. you have to use the SIMPLE ROOT method and then follow the procedure above.. it should work.. i never really installed a custom rom after i rooted.. cause by the time i rooted 2.2 came out which was my reason for rooting.. so hopefully that clears stuff up for those who did root using unevoked3
Unrevoked3 won't let go of my phone
I followed the steps described to the best of my ability. Everytime I run the RUU (RUU_Supersonic_1.32.651.1_Radio_1.39.00.04.26_release_171253.exe) it errors with Error 140: Bootloader error. Please help! I am a total noob. I just want to return to stock so that I can use the Sprint OTA Froyo update!
you have to do the simple root.. all you do is download the file on a windows computer HERE IS THE LINK
[Program] Updated: 1 Click SimpleRoot OTA 1.47.651.1 Edition - xda-developers
download run the program and then plug your phone in with usb debugging enabled.. first click the root button then it'll do all this stuff and the command box will turn red and follow the last few lines in the command box.. once thats done let the phone load back to the normal screen (lock screen / home screen). then you hit the 2nd button which is flash recovery. that'll do some more fancy stuff.. once again you'll return to the home screen again and then follow this guide using the 1.32.651.6 version.. just like the other guy said above... worked for me..
downloading froyo currently :D
I was able to do the simple root, but RUU is failing.
I am getting error 132: SIGNRURE Error.
Any suggestions?
Thanks,
You have to use the appropriate RUU with whichever version OTA you have... If you installed the froyo OTA, your SOL.
I did the simple root I waited until the screen went red and it stated to press the power button to enter the boatloader I pressed then it says to wait till it prompts you to install an update How long do you have to wait? I've been waiting for about 10minutes now.
Start over....reread it again. If you are doing it how you state above...you missed step 2 and 3.
Okay I am having major problems. I have installed the rooted froyo from odex. I would like to go back to 2.1 and be unrooted and install the unrooted froyo as I don't want to be rooted any more. Everytime I try I get Error 140: Bootloader error. Is there anything I can try?
I'm glad it worked for you.
You can try to flash RvU's first rom...it's stickied. Then follow my post a couple pages back...about using Simple Root...then the 2nd in the list of RUUs the signed one. But you might be SOL since you have a Froyo rom installed.
If you flash rvu you'll be good. As far as I know if you wipe. You can flash any Rom, even between versions.
Install the original 3.2 rvu.
Then run the original ruu
Update to your hearts content
Sent from my PC36100 using Tapatalk
First off, andorid newb here so be gentle
Here is the issue I am having right now. I followed toast's method of rooting my evo but would like to restore it back to stock.
I tried downloading HTC Sync (Update: i don't have any versions on my computer but would the stock version that was on my SD Card do the trick for all intent and purposes?), (which I keept getting errors on that page that you linked so if there is a mirror or some other means to download that would be great) and i have the RUU downloaded that you suggested.
If I back this up will that enable me to get the Froyo upgrade OTA?
Also i had heard that a sprint store would be able to install the update if you take it to a store. Would the be able to tell that the phone was rooted or unrooted if this method is followed successfully?
I tried downloading HTC Sync, (which I keept getting errors on that page that you linked so if there is a mirror or some other means to download that would be great) and i have the RUU downloaded that you suggested.
Yes they can tell...don't take it there. When you get it back stock...it will update you OTA....you have to have 1.47 to install 2.2. Go to htc.com and find HTC Sync and install it.
doxerwim
