How to Voodoo ***Updated 27 Mar 2011***KERNEL BUILT FROM SOURCE/SOUND/UNDERVOLTED
So I disable lag fix in cwm, (do I reboot? )put in download and use odin to install.tar? it would be the debloated full eb01 leak that includes the new cwm.
Sent from my SCH-I500 using Tapatalk
So I'm on sc 2.4 now, could I just flash adryns scvoodoo zip and disable lag fix and have voodoo? Or am I missing steps?
^^^^^^ I had the exact same question ^^^^^^^
tw105188 beat me to it... :)
sounds like you might have the wrong cwm.
first lets try flashing another voodoo kernel. if you have the superclean voodoo rom you can just reflash that rom.
start there and let me know what happens.
I tried flashing superclean 2.4...it starts installing then all of a sudden says installation abort.
Im guessing i should try flashing red CWM using odin and then disable the lag fix and then reboot? Im thinking thats my only options...im really trying not to break rule 1 and not panic...but i feel it starting to creep up a bit :/
lol. i remember that feeling. flash the proper red cwm and then flash new rom and then enable lag fix.
Reactions: whussain0
which rom should i flash? i flashed the new CWM and then went straight to disable lag fix and did a reboot and still stuck on samsung screen...should i flash SC 2.4 then go to enable lag fix?
Success! HUGE sigh of relief! Mike...thank you so much man for your help...i wasn't at panic mode yet...but i cant lie...i was gettin there...thanks again man
Just an FYI, the reason that link didn't work was because it was a search ID link. Searches expire after a certain period of time. ;)
i must have copied a link from a search. they expire after a time. like if you log into your bank website, copy the link. it will only work for a few minutes. i will fix it. thanks for the heads up.
i dont know bro because when i copy URL from the bar sometimes it works and sometimes it doesnt its hit or miss, and i do it the same way everytime
glad you got it working. i remember when i first started, how scared i got when i screwed up my phone. you get that crap your pants feeling. lol. now im like, oh look i bricked my phone..... oh well. and then i fix it.
alexajamez
