How to Voodoo ***Updated 27 Mar 2011***KERNEL BUILT FROM SOURCE/SOUND/UNDERVOLTED
Sorry I should of been more clear. With my explanation of a question (or what ever you want to call it ha ha) was just trying to make sure I didn't have to go
All the way back to dl09.
Sent from my SCH-I500 using Tapatalk
no problem. how did it work out for you?
since im going from dl30 superclean 1.0 to superclean 2.2 do i need a new cwm file before flashing 2.2? if so can someone please post a dl link for ebcwm
well i just went into recovery and flashed 2.2 voodoo without doing anything else. i was on superclean 1.0 which was dl30 and so far everything seems fine. If i start seeing problems i guess i will redo it with these.
did you hear lady android?
i tried that before i rebooted for the first time but it kept saying no. but when i rebooted she said lagfix enabled.
cool. get quadrent from the market and see what your score is. it doesnt mean much, its just to make sure.
Ok. I thought I had everything setup right, but I don't know what happened. Reinstalled apps I wanted, and tried to be particular about it too. Then I went into recovery from the power options. I installed the eb01 am/pm removal and the accurate power zip, and when I rebooted, I had an unending string of force closes, and had to end up pulling the battery and reflashing stock dj05 through odin. that's what I'm running right now until I hear what I need to do or where I may have gone wrong.
Is it... Clear data / cache install superdark, install test 6 voodoo kernel? Then what. it never says when to install the super clean 2.2 before or after the lag fix. Any help would be great. Thanks.
By the way...when I had it "fixed", out was only showing a base of dj05. Is that correct?
After a day of use with voodoo, there is a more snappy feeling as you are going thru the ui...especially scrolling up and down long lists of files like in root explorer and TI backup. No herky jerky, just smooth.
Best mod for the phone..next to themes lol
I'm running the EB01 superclean and loving it. I've been following this thread with some interest and I might want to give voodoo a try.
Are there any downsides? Does converting to voodoo mean that some things that work now won't work after the conversion?
I'm amazed at how much better the phone is without all of the bloatware. I'm getting the best battery life I've ever had since I got the phone, and it's really great to have the phone running almost as Google intended it. I'm ready to be more amazed...will I see a big difference in day-to-day performance? Any more improvement on battery life? I don't care too much about Quadrant scores.
I can tell you its a more smooth polished "feeling" of the phone. Just a general snappiness. Its subtle but its there. For me it didn't break anything, keep in mind I have just one day on it so I may run into something, but so far so good. I don't pay much attention to batt life but it didn't affect it negatively as far as I can see. I say go for it, its a pretty painless procedure. :D
Reactions: jack22182
Thanks. Might be what I go for with the next challenge.
I'm showing a baseband of DJ05 after installing superclean 2.2 - is this an issue if I want to install xda's accurate batter zip? Thanks in advance.
websitedesig101
