HTC EVO 3D: Issues and Problems...let's talk about them here!
Anyone notice that when you put an app shortcut on that the app's picture does not display correctly when you restart? This is really bugging me. I think its only for apps that were moved to the SD card. Can someone confirm...
This is happening for me too.
i still dont have a phone application in my lock screen or my app list. I did the update and factory reset and it was on my lockscreen again but not in my app list, then when I changed the other lockscreen apps it ended up disappearing
Did you guys have this issue on your older phones? It happened for me on my Nexus One since 2.2. ADB Launcher eventually refreshed them, but it took a little while.
There's enough space on the phone that I'm not even worrying about installing to SD
Didn't reset too often with the EVO 4G, but when this happened on my old phone it would eventually refresh them as you mentioned. That isn't happening so far on the EVO 3D.
Go to the app called 'Watch' in the app drawer. It will download the license and then play the movie.
Actually, there is app direct for the movie in the drawer called 'The Green Hornet,' so scroll down to the T's and you'll find it.
That's what I did initially and it had me download updates that took a bit to actually get to download now I'm in the watch app and there's nothing there. So now when I click the Green Hornet in the app drawer it just opens the watch app.
If you are using your own SD card and not the SD card you probably swapped before even powering on the phone.
The movie was located on the SD card that came with the 3D...if you swapped without moving it over then there are a few items on the SD stock SD card that can be moved over.
Oh yeah duh!! Thanks!! I didn't even think about it. I figured I'd have to download it. Thanks!
There's a phone button on the home screen.....why do you need a phone app?
.I only know this becasue I did the same thing and as I type copying the movie from the stock card to the EVO 3D.
Does anyone have a problem with the system sounds (mainly lock sound, phone dialer key press sound)?
I use Volume Toggle Free to set up sound profiles and one profile silences absolutely everything. Today at work, I had it on my silence profile, but when I pulled up the dialer to make a call, the key presses were audible. And when I checked Volume Toggle Free to see if I maybe set it incorrectly, it showed that my system sounds were suddenly cranked all the way up. So I tried to silence it again and I made sure it showed everything silenced, but it did the same thing. The system sounds turned back on. But when I silence it and do not open the dialer, everything stays silent; the lock/unlock sound isn't audible. As soon as I try to dial another, though, the sound comes back. I never had this issue with my Epic.
Has anyone else run into this? Maybe it's just the program I use and Volume Toggle Free isn't honeycomb/HTC friendly? Either way, it is very annoying...Oh, and my phone is up to date. I did update with the most current one that fixes the missing phone icon in the lockscreen.
Same here. The image for the apps I moved to my sd card do not come up after restarting the phone. On my og evo, it used to only take a few minutes to refresh but, like someone else said, it's been a few hours and still no images on the e3d. For now, I'm just removing the apps and re-adding them from the app drawer to fix... Still madly in love with my new phone :p
Update: Not sure if any of you are using skins but I just changed my skin and all the apps from my sd card that were missing the image were refreshed. So maybe try switching skins as a quick fix,
Re: EVO3D Issues and Problems...let's talk about them here!
The skins tip works great as a quick fix. Thanks!!
Uh oh.. anyone have any dead pixels?
I just got the phone this morning and now I have a single dead pixel. What the fudge man.
Guess I'll have to take it back already
That skin fix is genious! I actually like the burgundy one. I am a fan of the very plane jane look anyway. Big propps Rochell
Hey this is more a user issue more than likely...on my old phone(Pre that shall not be named) I was able to get e-mails as soon as they came in.
I am not getting them usually until much later.
I am using the Gmail app not the HTC e-mail app. any suggestions?
I get them right away, I use the HTC email app.
EVO - LUTION 3D
I use the gmail app and get them as soon as they come in
EVO - LUTION 3D
Is there a special setting?
Think I should remove and readd gmail account??
Go into settings, accounts & sync and make sure that you have your gmail sync'd. If the push is working the emails should be pretty instantaneous.
HandsomeZinck
