HTC EVO 3D: Issues and Problems...let's talk about them here!
Is there a special setting?
Think I should remove and readd gmail account??
I'm no expert but it also may have to do with your data connection. Check settings and see how you have it set up (email settings).
EVO - LUTION 3D
Re: EVO3D Issues and Problems...let's talk about them here!
hmm it did it them but I am using HTC mail now and it didn't show up.
Don't know what I am dong wrong here.
Why dont you just use gmail? In settings do u have google set to sync? click on google and make sure there's a check by gmail.
Yes it is set to sync.
And I tried Google and it doesn't work either. Where is another option to immediatley get mail...wasn't having this problem until the 1.13.update.
Running launcher pro as my home screen and now hitting personalize under settings just drops me out onto the home screen. No error message, but does nothing.
Just got my 3d and I noticed the stock mail app cannot login to my AOL mail when wifi is on. I turn off wifi and it works fine. Any suggestions?
Hey new EVO 3D users, I just got off the phone with Sprint. There are known issues with some, if not all of Gameloft's 3D games. I purchased Assassin's Creed 3D using the "3D Games" shortcut in the app drawer today. After the game is fully installed and I attempted to play it, it crashes on the "Loading ..." screen.
According to a Sprint rep, Gameloft is aware and will be updating the affected titles, however, you will only be prompted when you attempt to play. No ETA on the update. I've requested a refund.
Same here. The image for the apps I moved to my sd card do not come up after restarting the phone. On my og evo, it used to only take a few minutes to refresh but, like someone else said, it's been a few hours and still no images on the e3d. For now, I'm just removing the apps and re-adding them from the app drawer to fix... Still madly in love with my new phone :p
Update: Not sure if any of you are using skins but I just changed my skin and all the apps from my sd card that were missing the image were refreshed. So maybe try switching skins as a quick fix,
Thanks for the fix.
This must be a bug with Sense. Hopefully it will be included in the next update.
Hey guys first time using an Android and so I've been letting my EVO 3D charge as I read up on certain issues that appear. Some are quite obvious to figure out, but what is the recommend protocol to check my 3G speeds. I see that some people are showing really low dl rates and there should be a way to check?
My issue is regarding the weather animation sounds. When I go through the weather animations demo, everything seems to be working fine. When I turn on my screen and the clock flips to the right time, it begins to play the weather animation for "sunny", but then the sound stops abruptly and doesn't finish the sound. It sounds so weird because it doesn't play the whole animation sound. Anybody else notice that? Maybe it's only for the "sunny" animation?
Thanks for the fix.
I have lots of apps loaded, and when I restart the system not only are the Standard Android App Icon showing, but my apps on the SD Card don't show up in 'Applications' I have to go into 'Settings' - 'Applications' Manage applications' - 'Running' and Stop HTC Sense. When I press the 'Home' key it reloads and the Apps on the SD Card will show up in the list and the correct icons are displayed on the Home Screens.
When in youtube, and press more to save a video, pop up screen comes up and says "save to" and that's it. Anyone else?
EVO - LUTION 3D
I wonder if this bug happened with the update yesterday for the phone icon.
Definetly should be fixed by HTC. Somehow have to get this along to them.
*Update to this... The recipient of the pic mail is saying that she's not getting the pic. I will try sending to someone here at the office and see if its her or something up with handsent/picmail
If you upgrade over the phone Internet/picture mail won't work for 24 hours.
Download speedtest from the android market, happy testing :P
Reactions: dcxgod
OO also, lets say phones off but charging, how do I know when it's done? Does the red LED light change colors?
kitlis
