Htc m8 help im not sure?
Jonenone
Im not sure if its good to update to lollipop some people say it has improved my battery life and some don't. What i need to know is if my battery life is good, looking at gsam right now and it says 5 1/2 hours screen on time and im down to 18% people say and my settings are :
Wifi / Always on
Phone radio/ at 3-5 bars all the time
Screen brightness/ 1 bar
all the sync and everything is off
and i still not sure if updating will help or should i try recovery? ive already tried Factory reset. Do you guys have any suggestions on what i should do?
As an M8 owner who made the Lollipop update, my advice for you is to wait for the next update that should come with an update for Sense as well
Sent from my HTC One M8
My battery life is definitely worse , on kitkat I never could hit under 15% , but since lollipop came I came twice home with 2% remaining , and my usage has been the same , but what I noticed is that on standby the battery is worse idk maybe it's the 1st week with apps optimizing and stuff.. not sure though.
As the first reply says just wait, i had an m8 but sold it after the lollipop update as it drained my battery like mad.
I'm using the m8 and it was a great phone before the update to lollipop,I've had nothing but problems and spoke with htc who say it's Google's fault and there should be a update to fix most issues we shall see
baby boy
