HTC One Battery Life/Stats Discussion
- - - Updated - - -
For all users that have battery drain problems I recommend us do a Wipe Cache and Wipe Dalvik cache, that Give you again a good performance.
Give more suggestions please. Good night.
Enviado desde el techo de su casa
how do I do that?
i'm using htc one and i update my phone to 4.4.2 S.N. 4.19.1540.4 version when i done update i have problum with my battery status it show 1% . now i'm not able to to update because it show me ur battery is not not able to update plese charge ur phone, when i'm go to recovery mode it show normal battery status
Uninstall some sketchy apps and if that's doesn't work then factory reset.
Anyone else notice that there battery life has improved since the new Google Play Services was released a week or so ago? It seems to be managing my apps better and putting my phone is deep sleep faster and longer.
My HTC one battery status after using almost 3 days without charging. Economy use, wifi used when needed, updated 8/9 app from play store, listening mp3, used as a tv remote, sync google only 2 times. I use power saving mode and greenify. Its awesome.
I'm having the same problem. The phone goes from 7% to 1%. Is it because the battery lost 7% on 1 year? Nothing strange for a lithium battery, but i would like the phone to calibrate and learn the new capacity.
That's why i prefer phones with removable battery. From 4 years now, the phone could work properly again 100% if i just exchange the battery.
Actually just the opposite - since the update to 5.05 my battery runs down in 5-6 hours with only light use. I'm wondering what I can do about that.
dumpsterrentals89
